Recirculation...How Iimportant is it?
GofaST4life
2,897
132
Oct 21, 2007
Medina 44256, Ohio
This is my first DSM, and im already having a lot of fun learning new things and doing the work myself...im sure ill have more questions soon, but i wanted to now something, how imprtant is recirculation from your BOV to the intake? What are the pros and cons of recirculating and not recirculating?
Welcome, use the search feature, you'll learn alot more that way. Click on the search and try typing BOV venting, or BOV recirculate. Anyway, venting your BOV can be ok, if you do it the right way. When not done correctly, it can lead to unmetered air being fed to your turbo, causing hesitating, sputtering, and horrible gas mileage. Good luck :thumb:.
There are no pros, just bunch of cons. Please read the forum FAQs and search the forum before creating a new thread, there are literally hundreds, if not thousands, of threads on this topic. Welcome to Tuners.
xxraptor660xx said:
Welcome, use the search feature, you'll learn alot more that way. Click on the search and try typing BOV venting, or BOV recirculate. Anyway, venting your BOV can be ok, if you do it the right way. When not done correctly, it can lead to unmetered air being fed to your turbo, causing hesitating, sputtering, and horrible gas mileage. Good luck .
That is the small part, the main part is losing METERED air.
