Tranny Swap Question-RS
BurntRed22
Jun 8, 2006
Harleysville, Pennsylvania
I keep looking for the parts for my 420a but the problem is everything i find is a 2.4l
I have a 2.0L
Will it fit, because then it would be SOOO much easier
I have a 2.0L
I think you need to be a little more specific
BurntRed22 said:
Heres two examples, at the top its says it fits a stock 2.0 dohc... but the parts here say "turbo" (2nd one down) will this pressure plate fit?
http://replacement.autopartswarehou...-003&category=All&part=Pressure Plate&dp=true
Here is the clutch slave cylinder, here it says it fits 2.0 dohc but in advertisement it says 2.4?
http://replacement.autopartswarehou...l=ECL--003&part=Clutch Slave Cylinder&dp=true
I would have to say no, the 4g63t is obviously the turbo motor 2.0L and the 4g64 is the 2.4 spyder motor both mitsubishi engines and you have the 420a chrysler motor so therefore I dont belive they will work.
The reason it says 2.0 DOHC at the top of the pressure plate page is because its including the 2.0 DOHC turbo 4g63 not the 2.0 DOHC 420a, the slave cylinder page I dont know why it says that maybe just a typo or something I would try calling them and see what they say.
