Got a random spark miss at idle
90 GSX
322
Jun 24, 2004
Fremont, California
Okay basically, even with the timing adjustment plug grounded, my timing hovers around 5* then the timing light will have a slight pause and the timing will jump momentarily to 10 or 0 (not at 5). It's some sort of ignition miss, what could cause that? I did a conversion to the 91 ignition system and ECU but as far as I know it's all done correctly.
The car drives good, I get about 19-20 inches of Hg at idle. I mean I jsut don't understand this issue. I also have a problem where the car idles anywhere from 800-1000, not surging, just alternating randomly kind of. It's supposed to idle at 800 (stock gvr4 idle), that's how I burnt the chip because I'm using a gvr4 switchable tranny. It's weird... also, when you are driving and coming to a stop, the idle is supposed to stay up and then drop down when you stop moving, but that mechanism does work on my car. Idle switch works too, so it's not that. Another problem is that my fuel trims are out of wack. They indicate the car is dangerously lean. My low and high trims are at 115-120% and my medium trim is at 110%. No explanation for that either. Also, under any boost over about 3 psi I get knock which increases proportionally with the boost until I get about 25 counts at 11 psi (full boost right now).
This may be the weirdest problem yet... after the car has been running, if I shut it down and restart it, the idle drops to like 500 until I start driving the idle will eventually find itself, or rather it will go back up to between 800-1000 like I said in the first paragraph. When i searched I found other people with this problem but no answers.
Also, last problem... my car vibrates past 3500 rpm. It's not just AT 3500, it's past 3500 and it shakes up the downpipe heatshield and whatnought, I'm thinking it could cause phantom knock, but that does not explain my fuel trims...
Anybody care to give it a try? I'm really desperate to get rid of these problems, I can feel the car it wants to pull really hard but with all that knock my timing goes to shit under any real boost. I can't figure it out for the life of me, I mean I really took care when I built this car.
http://dsmtuners.com/forums/showthread.php?t=214284&highlight=transistor
After reading that post and a few others I am becoming convinced that my problem lies in one of three problems:
1- The coil
2- The power transistor
3- The noise filter
Here are my notes on each of those three possibilities:
1- I tested the coil (keep in mind, the car is a 90 but it's a 91 coil) and the reading was not within spec. So I tested another 91 coil and it came up with the exact same readings. Either both coils went bad in the exact same way, both coils were good, or the haynes manual was wrong. Can anybody post the correct specs for testing the coil with a multimeter so I can check it again?
2- I don't know much about the transistor. All I know is that symptoms that others have described are similar to what I'm experiencing now.
3- I got rid of the noise filter as per instructions on this website:
http://www.ecanfix.com/users/mdhamilton/ecuconversion.html
Tach works perfectly so i really don't have no idea if this is the problem.
Anybody?
Nobody in 2 days? This is surprising? Wisemen where you guys at, taking a sabbatical or something? I need help. My car is being held back right now. I need to know how to diagnose an ignition problem like I described.
