Remote Mounted Oil Pressure Gauge Sender
RamenPride
2,739
185
Aug 18, 2002
Virginia Beach, Virginia
Just thought I'd throw up a pic of my remote mounted oil pressure gauge sender (electrical gauge of course). This is actually my third oil pressure gauge, seems like the engine vibration took its toll on the previous two. Anyway, I got a stainless steel braided line from Summit Racing from the gauge accessories section. It's a three foot line meant for mechanical pressure gauges, but it worked fine. It contains all of the adapters that you'd need, except for a 3/8"NPT to 1/8"NPT adapter for the oil filter housing. I basically took a piece of metal, drilled a hole, bolted it as pictured, and used a hose clamp to attatch the sender. For good measure, I also looped a zip tie around it.
not a bad idea.
Gamble97 i think that kit is it, there is another for $34 but i think the one you have is it.
