DSMJim
- 3,328
- 41
- Jul 24, 2002
Thought I would post what I did on my balance shafts and see what you guys think. I'm not sure if you guys have even seen this before but I'm a bit different so here is what I did.
The description is in order of the pics below...
1)Here is the stock BS shaft and oil pump
2)I cut the front lobe off the shaft
3)Put it in the lathe and ground it down perfectly
4)I then shaved off the seond lobe between the oil pump and the first bearing surface so there is no imbalance anymore
5)This is what it looks like afterwards.
Basically no balance shaft anymore but a small light weight shaft that runs from the oil pump to the first bearing surface. I did this as this shaft is perfectly balanced so it supports the oil pump right to the first bearing surface of the old balance shaft setup so there is no small shaft spinning around unbalanced off the end of the oil pump.
