Injector Resistor Pack Wiring (1G N/T -> Turbo Conversion)
This is fairly short and simple. For wiring up your non-turbo 1G 4G63 to accomodate turbo injectors, you will first need to purchase a stock injector resistor pack. These usually go for $5-20CDN, depending on who you buy from.
This is simple and is the most common cause of consern for turbo n/t-ers. They just don't like working with wiring.
1. Open up the wire harness that runs to each injector. You will find 2 wires going to the plug on the injector.
2. Cut all the thick yellow wires running to EACH injector.
3. Take the white wire from the injector pack and connect it to just one of the wires you just cut. Make sure it is the one that runs to the car, not to the injector. The other 3 harness wires running to the car should be wrapped and tucked away.
4. Connect all 4 black wires from the injector resistor pack to the wires running to the injectors. Order doesn't matter.
Here's a simplistic diagram.
Remember do NOT use crimp connectors. Get your rear out and buy a soldering iron and solder these connections nicely.
There you go guys. No more PMs asking me how to do it. Thanks.
Hi, sorry for opening old thread. I actually trying to figure out how to *wire* resistor pack - I have turboed GS 4G63 and wiring colors are a little different, so I just need to know how ECU give signal to injectors - if it connect + or - and what i need to connect to resistor - ground or plus?
My injector wires are RED (ground) and GREEN with YELLOW stripe (plus i think) … RED wired i checked with ground and between injectors and that wires are connected between and ground.
GREEN wires are independent.
So for sure i need to ask - I can connect red wires like you connected YELLOW, right ?
This is a tech article not a thread but your confusion is understandable.
First, the injectors are not polar, there isn't a + and - to them. They have two wires, one that gets +12v from the electrical system and the other goes to the ECU where it switches it to ground to fire them.
On a 1G 4G63 NA the wires are thick (1.25mm) Yellow/Black, Yellow/Red, Yellow/Green, and Yellow/White that are all connected to the output of the MPI relay to get battery voltage. The ECU side wires are thin Yellow/Blue, Yellow/Black, Light Green/Gray, and Light Green/White for cylinders 1-4 respective. Not sure which car you are working on with the colors you listed.
The important part is that is you use low impedance injectors you need injector resistors and then go between the power source and the injector. On a turbo car they have a single power feed wire that all four resistors are connected to and then the other end of the resistor runs to one of the injectors with the other wire at the injector running to the pin on the ECU.
So figure out which injector wire is common to all and which wire runs to the ECU, then put the resistors in series with each of those power wires.
Its a EU spec N/A 4G63 what is turboed already. I checked all with multimeter, red wires are connected between each other and to ground, other wires are to ECU like you said and sends the signal to each injector. That connected wires with ground make sense to connect with resistor pack, because if i connect other wires like dummy, injectors can spray in one moment 😌 so like i said i wanted to know how exactly things works and be 100% sure about wiring.
I checked impedance of new injectors, old injectors and pack itself so dont worry about my knowledge, but always when i search something, its hard to find exact info about my spec, because in US they are not. So i checked always 2g GST specs, because they are closest to mine and at least i can spec and follow it.
Check my build thread in profile if you can and see my path of rebuilding.
  • For sale 1g 91-94 ignition coil
    91-94 ignition coil. Good condition. Have the weather pack that plugs into it and the stock...
  • Wanted valve body for 1GA AWD.
    Looking for a valve body for 1GA AWD.
    • kaanevrensel
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
