Advice on Engine Breaking In
Status
Not open for further replies.
boxer_05
May 1, 2004
brockton, Massachusetts
OK, so I pretty much overhauled my engine; I had the head done, I replaced pistons, the rings, the thermostat, gaskets, bearings, rods, the works. The only question i have is whether there are any precautions i should take now that I'm done and the car is drivable. How long do I break it in for? Highways or stay low speed? Any advice would be greatly appreciated. :dsm:
If you want a good strong motor that will have some power, dont baby it.
But at the same time, dont rag on it. Never keep it at the same RPM.
Keep it fluctuated. Keep the boost @ stock level. 14 ish PSI. (IF you have a trubo car)
You are gunna want to do this for 1,000-1,500 miles.
Change the oil often. You should have changed the oil after an hour of running the motor, and then again @ 100 miles. It goes like this.
Oil Change:
1 hour after running.
100 miles of driving.
500 miles of driving.
1,500 miles of driving.
2,500 or 3,000 miles of driving. <- one you hit this point, just start doing regular oil changes. Every 2,500 to 3,000 miles depending on how much you rag on the motor.
Status
