Mystic511
- 105
- 0
- Jan 19, 2002
Philly,
Pennsylvania
Ok, i'm really desperate for some guidance now.
I bought a whole new rear caliper and mounting bracket for my 92 tsi awd (driver side rear).. I can't figure out how it goes together. The caliper that's already on my car, the bottom part of the caliper is a bolt, and the top part is like a hinge that just lets the caliper swing up.
Since I couldn't get the caliper off the bracket, I figured I had to get a whole new assembly. The caliper and bracket that I bought from conicelli came seperate and not hinged like I thought it would be. I also got two bolts and two clip/sleeves. The new caliper looks exactly like the old one, so i'm not sure how to mount it to the bracket. There doesn't seem to be a place for the bolt on the top of it where it is suppose to be hinged and swing up.
So basically I have the bracket (that bolts to the hub), two bolts, two sleeves, and the top part of the caliper. Do I have everything I need? If so, can you walk me through how to put it together?
My car's been on jackstands for like three weeks now, so I'm desperate to get it done this weekend.
Thanks in advance for your help, I truly appreciate it.
