FS Performance parts.
frankozz
283
3
Aug 21, 2008
san diego, California
most of the parts are brand new and haven't been used.
Here's the list of stuff for sale.
Built bottom end $1000 plus shipping, purchased in 2010 from Joe @ Redjack Racing AKA Bigjdog84, it hasn't been used since I bought it, it does however have a bit of surface rust on the deck from sitting in the garage, I haven't tried to remove it but was told that it was an easy fix.
**Original description from his FS ad**
.20" over Wiseco forged pistons
SCAT Forged H-beam connecting rods with ARP 2000 rod bolts
Mitsu OEM main bearings, clevitte tri-metal rod bearings
Balance shafts eliminated
Stock, uncut, balanced crankshaft
OEM main caps and new OEM main bolts
OEM oil pump with OEM stubby shaft
All new seals, front and rear main
All machine work was done by S&W machine shop in moosic PA. Motor was bored and honed using a torque plate, jet washed, and resurfaced for an MLS gasket
Has perfect compression 165 PSI and looks great, was used about 300-400 miles. Motor was broken in properly and soon after ran one 11.4 pump gas pass at the track on low boost and junk 60'.
BNIB Crower 272 cams $old
BNIB Crower springs and retainers $old
BNIB Crower 1mm oversize valves, supertech bronze guides and valve stem seals $300
BNIB Map h11 headstuds $old
BNIB HKS timing belt $old
BNIB ITM revised lifters $old
BNIB Evo oil cap $old
BNIB Tial purple bov 10 psi spring $200
BNIB OEM MLS headgasket $100
BNIB Tial purple 38mm wastegate $old
BNIB OEM timing component kit $old
Used HKS cam gears, unknown miles $old
RX7 FD rims, no tires $old
FP3065 turbo kit $old
This was Jake Montgomery's turbo, the turbo has a Tial SS v-band .82 A/R exhaust housing and a fairly new garrett CHRA 3000 miles on it and is in perfect condition! No shaft play. It hasn't been used since I purchased it from him.
Along with the turbo, you will also get a brand new Redjack Racing v-band manifold, v-band side exit exhaust, v-band wastegate dump, Tial v-band clamps and Tial 38mm wastegate.
Buschur Racing 1G FMIC $300 shipped!
2.5" piping and a 24" X 8" X 3.5" core intercooler. Kit includes all couplings and t bolt clamps. Has a TIAL bov flange and an AIT bung.
Magnus SMIM $old
1g head, 75mm throttle body.
Brand new Ksport coilovers $old
Installed only, Haven't even dropped the car from the jackstands.
If you want you can send me the paypal money as a gift so they don't charge 3%, I am a trustworthy and stand up guy, 100% feedback here on talk and I won't run away with your money. :p If you are not comfortable with that, please add 3% to cover paypal fees.
Anyone interested in the shell?
$600.
The good:
88k on body.
No rust.
No body damage.
4 bolt rear and driveshaft.
Tranny and transfer case. No clutch, no grinding gears.
Black powdercoated motor and transmission mounts with prothane bushings.
The bad:
Car is located in Tijuana, Mexico.
No shocks, springs, rims and tires. Will need to bring your own in order for the car to roll.
Interior is semi stripped, no backseat and plastics in trunk removed.
No lowballers, I will not sell anything out of the car, I don't want to end up sending the shell out to the scrapyard. 4bolt rear and transmission alone are worth the asking price.
In all her glory. :)
Yes and no.
When I purchased them only 15 came in the set, I sent an email to Maperformance and they sent me a single lifter, I lost that single one and they don't sell singles, so I still have them but I only have 15.
is that Timing Kit OEM mitsubishi? and does it include all the pulleys and Hydraulic Tensioner? also would you sell that water pump?
I'll take that timing kit if u have it man, just waiting on you to respond. Wish you could of just posted your number on here. Let me know if you'd be willing to sell that water pump with the timing parts as a package deal or something.
