90AWDTalon
- 877
- 3
- Jan 5, 2003
Everett,
Washington
I went autocrossing for the first time with my Talon. I had gone about 6 times four years ago with a Honda Delsol Si. I ran Novice and CSP. I ran novice with the Talon and plan on staying there a few more times. I'm trying to figure out what class to run after that. I had planned on running open street, but I missunderstood the rules when I was thinking this. The guy that won that class had a turbo miata and was extreamly fast, he beat me by 12 seconds. I went and checked his car out and saw he had R compound DOT tires. I plan on using real streat tires, so this class is out. The other options are C modified and Street Tire. Modified class can runs any tire, I'm on street tires so not a good class for me. That leaves Street Tire, the problem with that is its indexed based on what class you would be in, that is C mod for me, this is the 3rd from the top on the index list . Means it'll be pretty much what ever time I run against everyone else's handicaped time's. My car is not set up for autocross, my turbo is whats putting me into modified. My suspension is stock right now, but I ordered springs and shocks last Friday, but its still not a race setup.
So I'm curious what class you guys run?
Is Street Tire going to be my best option? It'll be a long time before I buy autocross tires, if at all.
My main goal is just to have fun, but I'd like to be as competitive as possible.
, I didn't even notice that you said you mistakenly said r-compound
