Blizzz
- Jan 31, 2005
Pittsfield,
Up for sale is my 1995 Eagle Talon TSi turbo 5 speed. The car has a good amount of mileage on it, and also has a salvage / rebuilt title so know that up front.
The good: has a fresh coat of paint on most panels, new transmission installed not too long ago, Just replaced the clutch master and slave cylinders, timing belt & cam belts/ sensors replaced. New wiper blades. Recently passed NC state inspection, Good amount of tire tread left. Car was the top of the line back in 1995 and has all the options like leather, power everything, cd / cassette deck (no longer works needs reset), sunroof, cruise control.
The bad:
The car does not have AC. I recently had it charged with freon and it worked for about a day then stopped working leading me to believe there is a leak somewhere in the system. The car also has an exhaust leak which should be able to get fixed for reasonably cheap if you want to. Check engine light will come on and off, I have not checked what the code is, but it could be
related to the exhaust leak. Ceiling material is starting to separate in the cabin a bit. There is also a crack in the windshield which is basically hidden from view (low on the windshield). Front bumper has some paint peeling on it.
The car had a rough idle when first started up. After about 20-30 seconds it was ready to go. If you were to hop in the car, start it up, and immediately try to drive it was very hesitant and would stutter for about 50 feet. After that initial startup it drove smoothly.
Recently, I went to start it up after sitting for a month. It fired right up, but after driving a few miles I noticed it started getting hesitant. The boost gauge reads full boost but the car wasn't pulling the way it should. I think the turbo is probably blown after all these miles, and I would suspect there may be damage to the engine. So basically I'm selling this as a roller, although all the parts are there and could possibly be fixed easily. I just don't have the time to dick around with it. I've got two other cars, and although i drove this one the most it's not necessary to own.
There are a bunch of pictures and a couple videos here:
Index of /random/talon
I'm looking for $2k for everything.
e-mail me or call... i need to get rid of it.
[email protected]
(413) 841-2687
By the way, the car is located in Apex, NC.
The bad:
[email protected]
(413) 841-2687
