Car NOT starting...HELP!
g0tEclipseD
292
Oct 29, 2003
San Diego, California
Ok so Im pulling my car into the garage and its running fine like normal. I turn it off and see I didnt pull in far enough so I try to go turn it on and NO luck. Nothing happens. Doesnt Crank or even struggle to turn on. Lights, Windows, power everything iw working but I try jump starting it anyways and still no luck. Roll out of the garage and friends push it and were able to turn it on and drive it normally (stalling easily). Go to try and turn it on and once again no luck.
When we turn the keys, the dash lights dim a little bit and u hear the relay"click" and kinda a light whistling sound.
Whats the problem here? Could it be a bad starter? Where is the started on the car located & what should I check? How much is a new starter?
Thanks for all the help.
PS: Car Info
Stock (only free mods & k&n)
1992 Eclipse GST
Hey, not sure of your problem but I just put in a new starter less than a week ago.
The starter cost me $140 with a $30 core charge so that brings it down to $110. The starter is in a tuff spot, its in the back of the engine bay on the transmission. if you take off your uicp and look down on an angle you should be able to see two bolts I believe its the top bolt that you should see a wire tightened down to. Its just a pain in the neck trying to manuever it out through all the other hoses. (note, It wont fit out the bottom of the car!) Hope that helped you out alittle bit.
Also, When I got the new starter back in, the car wouldent even turn over, just a clicking noise...The little black wire that clips on to the starter fell off..just a side note incase it happens to you!
Rob.:thumb:
Check your battery voltage. Should be above 12 volts. If you get the car started, check the voltage on the battery. It should be reading above 13volts, as its charging. If the voltage continues to drop, your altenator is shot.
Sounds as though your altenator went bad and the battery voltage is too low to power the engine electronics correctly.
Check fuses underhood in the fuse block. Check fuses in the positive cable on the battery.
  • For sale 4G63 FIC 1200cc Injectors
    FIC 1200cc Injectors $350 + shipping and paypal fees* injectors were cleaned 6/23/26You must...
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
  • For sale 1g Flip up headlight
    One red flip up headlight and the black trim piece for the other
    • Anthony Hornback
  • For sale 2g sunroof shade cover
    I have 5 sets of these. They are freshly re upholstered. The material I used was black suede. I...
    • Jose gonzalez
