DuskTilDawn
- Feb 27, 2003
SPORADIC I have sparatic idle, sparatic misfire that throws a CEL, and sparatic fuel or boost cut...not too sure which it is or if it is even one of those things. Well anyways, I need to know where i can get a vaccum hose kit for my car. It is a 95 Talon TSI AWD. I have seen this vaccum hose kit before...just not sure where. Then I need to know how I can stop the sparatic misfire, and the sparatic boost/fuel cut. I am hoping the sparatic idle is just a bad vaccum line or something. I am probably going to try and get the egr block off plate, some people said that might help the sparatic idle and "cold" start. But the boost/fuel cut....it only occurs when i am really getting in it....and its in higher rpms and boost level. The car starts to studder very slightly as a "warning" to me to let me know it will happen and I need to let off...but if i stay in it, it will lose its ass completely, sometimes worse that others. Sometimes its a jolt, and then sometimes the car just doesnt want to keep pulling boost. So I dont know. I am in a bind, do not know what to do. Just trying things as they go. I already cleaned the throttle body and throttle position sensor.
So anyways, I need help. Whatever information anyone can give me is appreciated. Thanks.
Just in case: My mods are, 92 6 bolt swap, (because of the swap someone said i am getting sparatic misfire because of the cam angle sensor or something), Dejon Tool upper and lower intercooler pipeing, with the J-pipe on a 14b turbo. Turbo XS blow off valve. Dejon Tool intake, with the recirc. tube blocked off.
