gr82av8
- Oct 25, 2002
.....crankwalk. Recently, my car developed an extremely loud creaking noise whenever the steering wheel was physically turning. Everyone I talked to pretty much assumed it was the ball joints. I haven't been able to take it in to find out, though, because now I'm having trouble with the clutch pedal and shifter. The pedal has virtually no resistance. When pressed to the floor, it stays there. With the engine running, I can't even begin to get the shifter into any gear but reverse where it will only grind. With the car off, I can shift into any gear.....but when I try to start the car in gear it lurches forward for a second until the engine smooths out. I was able to circle my cul-de-sac and pull into the driveway in 1st gear, with the clutch pedal depressed the whole time.
I've tried to be as specific as I can about the problem. Does anyone have any suggestions? I'd appreciate it.
Chris
Edit: I was just reading another post about slave and master cylinders going bad. I recently had the slave cylinder replaced. Could it be that I just need a new master cylinder?
Chris
