somethings wrong [Boggy acelleration]
TazManianDevil
239
Jul 8, 2003
Lakewood, Washington
my problem is when i floor the accelerator of my car at speed of 45mph it hesitates to accelerate its like go stop go stop go stop like the engine is having a hard time accelerating hard. 2 months a go i change my fuel filter (fram) is it the fuel filter? do i need to change my spark plugs? clean my air filter (k&n 7 months old)? or is it seriouse engine problem?
Originally posted by Spidey
99% of the time your situation is caused by fouled plugs and/or bad plug wires, replace them and try again.
that worked for me. try that
any brand of spark plugs/spark plug wires? what the right gap of spark plug? i always panic when i feel somethings wrong with my car :D i thought it's seriouse
Originally posted by DSMeclipse4G63
Does it feel like its boggin under boost? If so it may e your coil pack.
Andrew
where can i find that coil pack? is it easy to replace? is it expensive? i hope not
For plugs get NGK BPR6ES's
For wires, I just got some new ones from NAPA but if you want something better then get Magnacores.
i had same problem with mine it bogged only when i floored it and all it was a fouled plug and my valve cover was kinda loose and there was oil in plug hole. it turned out to be a 11$ problem so go try that. sorry every one else already told you this but what the heck. later
nick
NGK for both, check out dsmparts.com they usually have a package deal. Spark plugs should be gapped somewhere between .028 and .032, I usually keep it at .028.
problem fixed!!! i change the old plugs and wires with magnecore spark plug wire and NGK spark plug thanks guys for helping me:thumb:
