tranny actin up, brakes buzzin, high oil pressure
sleepintalon
Dec 4, 2003
oak creek, Wisconsin
k well heres my problem my tranny acts up from time to time. sometimes it doesn't shift smooth or it doesn't shift at all until i let off the gas and then give it some gas. i checked the fluid and its red and full. what are the symptoms of havin too much fluid?? i don't have any fluid spewin out. also sometimes when i shift from reverse to drive and i press the gas i get hesitation and it jerks and then goes. ok so thats it for the tranny. now for the oil pressure, when i'm drivin on the highway i get really high oil pressure and recently its goin high even just goin 40 or so. is there a way to lower pressure just a lil. i use part synthetic 5w-30. and my brakes are buzzin when i have the brakes applied even when sittin at a light. they don't squeak its a high buzz from the engine.
thanks for the help
Why don't you decide which problem you want help with and see what happens. Throwing the whole kitchen sink with dirty dishes out there isn't going to get you very far. Deal with the simple things first that you can understand and do then get into the more complex specialty areas.
Cheers,
GTM
i can understand it if someone were to explain it. these are the problems i'm havin so i figured i'd throw all the dirty dishes into one sink instead of three. if you can help that would be better than tellin me i should seperate all the problems.
Your tranny problems belong in the tranny forum.
Your oil pressure needs to be checked with a mechanical gage that is known to be accurate.
Your bakes probs need more input from you, just too obscure for me.
I don't get paid for giving advice or helping anyone, I do this like most everyone else for enjoyment. I gave you my 2¢, take it or leave it.
Cheers,
GTM
hey, i'm sorry i didn't meet your criteria for helpin me out, your 2 cents didn't really give any info at all. i checked the tranny forum. i checked the oil pressure with a mechanical gauge. these are problems therefore i put them in the problem diagnosis forum. the only thing about my brakes is what i described, buzzin, not squeakin, when the brakes are applied. they aren't weak or pulsin, there is just a buzzin comin from the under the hood. i'm not just askin you for help there are other ppl out there to help. i help other ppl with their problems i know about so i figured someone could help me. i don't get paid either.
