LessIsMore
- 98
- 3
- Jul 30, 2003
I was experiencing a nasty noise and vibration coming from my motor so I pulled the oil pan. In it I found my rear balance shaft bearing split at the seam along with some other metal particles/chunks from the bearing craping out. I also removed the 2nd and 3rd cylinder rod caps and the center main cap. The bearings on the rod caps looked good and the crank journal had very small scratches that were only visible and couldn't be felt by running my finger nail across. The main bearing that I pulled had small nicks in it on one side that could be felt and the crank journal had small unfeelable scrathces.
Now my plan is to eliminate the balance shafts by replacing the rear one with the stuby shaft from the mirage and leaving the front balance shaft in the block with no balance belt.
My question is whether or not the wear to the crank and bearings is normal for a motor with 100K+ miles? Can I get away with just eliminating the balance shafts and leaving the rest as is? Is there anything particular that needs to be done when reinstalling the rod and main caps or do I just torque them back down and be done with it? I'm new to engine bottom end work and any insight would be appreciated.
