black97GSX
- 152
- Jan 4, 2003
Raleigh,
North Carolina
My 97 GSX was in an accident about 2 months ago, involving deer, after doing tons of work to it like, 1G block swap, internals, turbo, fuel system . The car is finally up and running after about 2 months, and a new apexi skyline FMIC and a bit of exterior work. At first was running shitty, sputtering when it was about to hit boost, but i messed with the SAFC and just let the motor run for a while and then started running better. I guess the injectors and plugs didnt like the 2 month old gas very much. Even though the motor was running better there was still a high pitch beeping kind of noise coming from the air filter. I know it wasnt coming from the air filter only, but it had to be coming from someplace else in the motor and being sent out the air filter. Have never heard this on my car before or even heard it happening on other DSMs. Not sure at all what it could be, will check it again tomorrow, if you guys have any ideas or info that would be helpful. Hopefully it will just stop on its own. Later
