ltho98
- 110
- 2
- Oct 14, 2003
Okay, i've about lost my mind trying to diagnose my non working water temp and oil pressure gauges.
I have a jdm motor and instead of the oil pressure sender being located next to the oil filter, its located on the lower left hand corner of the head, looks like its tapped into some channel or something. So i just routed a wire from a broken one near the oil filter, assuming that wire is supposed to goto the oil pressure sender to the pressure sender up by the valve cover-- nothing.
Also, water temp doesn't work.. once in a rare while when i floor it, the gauge will spike to hot, but other than that it just sits at cold. I've checked the voltage output from the ecu on the temperature sender in the t-stat housing when the car is on.. and it reads 0V.
When i have the car hooked up to a data logger it shows coolant temp and looks normal, but the gauge doesn't seem to be working, is there a temp sender for the gauge?
