hollandeclipse
- 39
- Nov 20, 2003
Europe
I've installed a 255 lph walbro, 650 cc, Venom fuel rail, Apexi S-AFC and I have my 1g MAF modified, I'm now encountering the problem that I cannot raise my fuel pressure at idle, max. fuel pressure rate is 19 psi and it should at least 27 psi, I've fitted an adjustable fuel pressure regulator which worked fine on my other car. I've already tried to block the return line but this has no effect in raising the rate and also unplugging the vacuum feed didn't gave any response.
Any suggestion why my fuel pressure is too low?
Kind regards,
Johan
Kind regards,
Johan
