GSXlaunch
- 392
- Sep 3, 2003
I just removed the lower fitting cap-off on the oil filter housing on my 90 GSX. It was fairly easy once I warmed it up with a propane torch. Anyway, I went to install the angled fitting that came with the RRE kit and this is as far as I feel comfortable tightening it. Does this look right to you guys?
http://f2.pg.photos.yahoo.com/ph/leche1103/vwp?.dir=/1991+GSX&.dnm=RRE+SS+OL.jpg&.view=t
I have a feeling that if I go any tighter either the threads will strip or the filter housing will crack. I did use high temp threadlocker on the fitting. It is tight already as I used my adj wrench to grab it. Lastly, when I go to attach the ss line to this fitting can I use regular teflon tape or should I leave it as is and tighten it? Thanks fellas
