between 3000 and 4500 rpm my car will cut back for a split second
tboostndsm
Nov 23, 2003
between 3000 and 4500 while building boost I will get a small quick
cut back that you can hear in the exhaust tone.Iwanted to know if this hurts my engine or turbo and whats the cause and solution.It have a 3" straight pipe exhaust w/o cat or muffler that is welded to the stock downpipe after the flex section.Im buying a muffler asap and hopefully this will fix my little problem.I would greatly appreciate any knowledgable information or tips thanx.:dsm:
check your wastegate lines may have poped off. and it is fuel cutting
if you have a boost gauge see what it reads under boost if it is maxing out the gauge.
all of my vacuum lines and wastegate/turbo lines are connected.How much power can i get before fuel cut?yes I have a boost gauge and I have no problems building boost and when it cuts out my boost doesnt drop or flicker the gauge.I have a feeling its the exhaust.
i didn't see the part about the no muffler it may be a back pressure problem.......fuel cut will happen at like 7500rpm or around there
lean the car out mine did the same thing under boost anything over 14psi so i leaned it out a little and wooohoooooooo runs like a champ ...:D
hey thanx for ur help.hey you dont happen to know anyone selling a 16 g do you,(p.s. how did you lean your air /fuel mixture what management system are you running
