gyuen
- Aug 3, 2002
Calgary,
Decided to build my motor from ground up after i spun my balance shaft bearings. So went with CP 20 over pistons and eagle rods to start. Got a phone call from the machine shop after hot tanking and they told me the bearings had spun so bad they do not fit back in. I have an eliminator kit but am worried the bearings will fall out. Any suggestions? Thinking of just welding the oil passages shut. Don't know if it as a possibility or not. They sent it out to see if spray welding was possible but they told them no so little fustrated considering just finished paying for machining a bad block. Thanks.
