Transmission problem diagnosis
newbile_silence
Nov 6, 2003
I have had BAD trouble with a 98 Eclipse RS automatic that I purchased. The car has a Star Performance Stage 2 Kit.
To go into some general detail, as I don't know all THAT much about cars, at 40 miles per hour my vehicle hits 3000 RPM's and then it hangs there. If I'm accelerating faster with O/D engaged, the car has also downshifted on it's own before while I was in 3rd gear.
Numerous mechanics have noted that my car is operating in limp mode. I've been told that this means the car has transmission issues.:( I replaced the transmission for $800 and have had the same issues. At first, I just had the speed sensor replaced for $300. :rolleyes: After that work my speedometer failed to work anymore. :confused: At this point I'm at wits end. Having replaced the transmission and seeing the same symptoms, the only other explanation the mechanics have given me is the possibility that I need to have my vehicle's ECU reprogrammed, reset, recalibated, etc.:barf:
Is there anyone with a vague idea or similar scenario? If so, what did it take to solve your difficulties??? :thumb:
alrite man ill help u out....why for 800 bucks would u get a different tranny....and its AUTOMATIC??? dude u should have got a conversion number one....and second of all automatic transmissions are bound to have problems....there is to much shit that a auto needs....u should have went 5spd....but since u have auto u need to reset the ECU....or upgrade the ECU.....let me know what happens
:talon: 96 Talon Esi (5spd)
