eclpsegsx12
- 214
- Feb 16, 2003
Tucson,
Arizona
ive posted this before but didnt seem to get many replies.....the deal is that i have recently bought an evo III 16g about 2 months ago....i put it on the first time with ported manifold, and o2 and the boost hit 10 and creeped to 20 by redline or so......i took it off, sent it to road race and they did the 34mm wastegate flap mod and ported the entire turbo while i continued to port the manifold and o2 housing.....i got it back, put it on and it did the same damn thing.....i can run 10psi and it will creep to 20 or i can set it for 20 and it will stay at 20 and sometimes(when its cold) creep 1-2 psi.....i have no idea what the problem is and i thought id once again, go and try to fix it while my head is off and everything....i run a turbo xs standard MBC and when it is closed, it hits 10, then 20 at high rpms....when i run it to the wastegate, it hits 10 and creeps 20......someone please help me with this problem....this turbo has been nothing but problems for me ...grrrr....thanks
