Sounds like a miss
TalonR
115
Mar 4, 2003
Oceanside, California
Hey I need some help and it is driving me nuts....My car sounds like it is missing....So I went ahead and replaced the plugs and wires..but to no solution...A friend mentioned the fuel filter might be clogged..So I am replacing that now....If that doesn't work is there any other suggestions....I would really hate to think of the coil pack, thing is expensive...Any help appreciated, thanks......:thumb:
O.K the fuel filter is replaced, still that damn miss......Now the filter wot quit leaking.. oh well.....Could the flex pipe leaking be causing the "missing" sound..I dont know......Well its like the third flex pipe i've put on and they all start leaking....so i haven't a clue....Any advice
sounds like your exhaust isnt hung right if your going throught that many flex's. ya did the plugs.. but are they gap'd right ? on the fuel filter.. did ya use the new crush washer? ( or did ya use one at all ? )
Yes the plugs are gapped right and the fuel filter has the crush washer.. The exhaust is hung correctly, using all the factory mounting points, I can double check it though.....I am thinking of just having a diagnostic done on it so I quit dumping money on guessing...Thanks for all the help.....Any more suggestions!!!!!!
