Rally1
- 60
- Oct 19, 2003
2002 WRX,
On start the engine idle surges to 2k, up and down every second.
Common on 1G DSM was the fact that the capacitors in the ECU tended to leak. So I replaced the ECU with another used one that had the caps replaced. The problem still exists.
The interior lights and headlight will flicker rapidly when the car is on, if i give it gas (RPMs over 2k) they lights are solid.
With the car off (ie just on Batt.) there is no flickering.
I am guessing alternator. It is an "upgraded" alternator, rebuilt to put out 90A rather than 70A.
If I put a meter on the battery with the car on the voltage sits at 14.2V, even though the lights flicker, the number doesn't change. And i tested it with a digital VOM and an analog one so i could see the needle swing (it didnt).
Does it sound like alternator, or does it sound like a voltage regulator or something else?
Need more info, just let me know.
