HybridAWD
- 136
- Mar 9, 2003
Ok here is the list of mods that could have effected my car
MSD Dis-2, 1g CAS, Custom coil on ignition (wired for a 97+)
- I've narrowed it down basically between the power transistor or ecu. My question is how do i test that the ecu is sending the correct signal to the transistor?
- I did the test that the FSM said to do for the power transistor and well it passed. I checked for resistance in all the wires from the CAS to the Coil connector.
- I turned the ignition on and had the Ecu connector off to check for voltage from pin #10 & #23. My readings were 12 volts on one pin (1 & 4) and 8ish on the other.... i take it that they both have to be 12 volts?
- I would think my CAS is ok since i have spark on 1 & 4 and that its not wired wrong.
- I tested the custom coil setup on a 99 GSX and it worked fine, had a firend with his 97 run it for about 3 weeks or so.... so that eliminates that.
Last ?.... How do i know i have the injector wires hooked up to the correct injector?
If anyone has any idea how to test the ECU or something else let me know so i can finish this hybrid setup!!
