Mason
- 44
- Mar 11, 2003
Did the DIY UIP. After I did it the check engine light came on. I knew it had to be a leak. I took the pipe off and fiberglassed where it was welded. I think that fixed the problem because I took it on a road test and the engine light went out. My question is, was the light supposed to go out by itself or was I supposed to have the code erased with a scan tool? Another quick question, before I did this ny max boost was at 14, now its at 19 and at high rpm it spikes up to 21. Is this good or bad?
