Surferdude
- Apr 24, 2003
Toronto,
Hey everyone
I am having some serious issues with my 2nd generation DSM, to start it off here is what I have (modifications)
2nd Generation GS-T ... Modifications include
Injen Intake
K&N fipk
Killer 28 Turbo Charger
Manual Boost Controller
Turbo XS Type H
2.5 exhaust system / straight pipe
Boost / afc gauges
Now here is the first problem
I had my car serviced just a few weeks ago (And all the problems occurred)... I had my plugs changed (not the wires) engine flush / oil change (forgot the type of oil) injectors cleaned
Since then my speedometer has been acting up, it dose not read the proper speed and jumps all over the odometer (all the time) I notice that when I shift down or hold the clutch (and possible brake) it just completely drops to 0 kmph (no idea what is wrong here) but the Speedo is not broken, I took it out tried to put it back in
Next issue, no matter how low / high I set my boost controller (manual) it seems to jump all over the place in 1st and 2nd gears (from 12 23 psi) when in 3rd gear and 4th gear it tends to calm down and go to a norm boost setting example 17 psi
CAR RUNNING RICH This happened at the same time the speedometer messed up, it seems that my car is always running extremely rich (I have no idea whats going on) but as soon as I kick some boost it goes full rich and if im really going CUT it just dies out meaning the car sorter back fires looses all power I dont know if this is the turbo xs type h not holding the boost but someone please help me
Finally electrical issues
My heater control lights are not activated (meaning when I put the lights on they are dead), on top of that my horn buttons do not work and hazards .
Im really lost here and have tried hours and hours at figuring out whats wrong
If you can take the time to help me out it would be greatly appreciated
Thank you very much
PS I have decided to purchased a crushed + ported bov (1g) to eliminate the venting to the atmosphere) will this help with my bad rich issue I also noticed when I threw on the turbo xs I lost a good amount of power weird ? or untrue
Injen Intake
K&N fipk
Turbo XS Type H
Boost / afc gauges
Thank you very much
