OhmegaMike97awd
- Oct 10, 2003
My 97 talon suddenly just quit idling. let off the gas, and it dies. I tested the ISCM and it's OK, there are no DTCs, no check engine, no clue! I ended up cranking the BISS screw out about 3-4 turns, and disconnecting the ISCM (to prevent it from damaging itself) as a temporary fix. I'm lost. Any clues out there??? It seems like the car is running richer now too.
What have I checked? The fuel press reg, all hoses and vac lines, pressure tested from the turbo to intake manifold (no leaks), ISCM checked the coil resistance, and mechanically seems fine. No errors showing up on the pocketlogger. Checked intake air temp sensor, coolant temp sensor. I didn't try running it with the MAS unplugged cuz I have big injectors. I may have to go back to stock injectors and disconnect the SAFC to help find the problem? Donno...
This happened suddenly, was never intermittant. one stop light it's idling fine, the next it died as soon as I put in the clutch/let off the gas.
Any ideas would be appreciated!
Thanks,
Mike
Thanks,
Mike
