GS-TURD!
- Sep 28, 2003
I just bought a 95 gst with 127k miles on it.When I start it up it runs fine and no smoke,but after about 3 minutes of just idleing it pours blue smoke until I get in and drive then it goes away after about 2 minutes and will not smoke until I shut it off again.I took the turbo off and took it to a local turbo shop (Turbo auto) and they said the turbo is fine as far as the smoking goes.He said it was symptoms of a pcv valve,so I checked it and it is fine.Also there is a valve with a nipple broken off of it and the vacuum line I plugged.It is the 2nd valve to the left on the firewall on a 2g.Can anybody tell me what this is?
P.S.I searched but nobody else seemed to have my same symptoms.Thanks in advance
