nolimits
- 61
- Jul 11, 2003
I'm in the process of some other work including TB, and decided to remove the balance shafts. The vfaq has the procedure, but adds this:
Is that saying that only the rear shaft needs to be replaced with the stub shaft, while all bearings remain and the plug isn't used since the gear is still in place?? Why couldn't the belt be just disconnected, and save a lot of labor, since by leaving the shaft in maintains oil pressure? Would the oil pan even need to be removed in this case? Maybe I'm missing something here! Please help!
Note that you don't have to replace the front shaft bearings with these blockoff bearings. It is recommended that you do so if you are working on an engine that is out of the car, but if it is in the car, many people have had no problems with just removing the balance shaft belt and letting the front shaft "block" the holes in the front bearings. If you leave the front shaft in place, it shouldn't hurt anything. Just make sure that you leave the sprocket and spacer on the front shaft so that it is locked into place and doesn't move back and forth in the bearings.
The only real advantages of using the blockoff bearings are:
The oil pressure will be raised slightly as the oil will not be exiting through the bearings. On an older engine with wear in the oil pump, this is a good thing.
The stock bearings are 2 piece bearings, and if they are very old, it is possible that the bearings can come apart. The possibility of this happening is extremely low, however.
