Where to buy lower gasket set??
nolimits
61
Jul 11, 2003
I need the lower gaskets needed for removing the balance shafts (Turbo Drain Tube, Oil Pump Cover, Oil Filter Bracket, and Oil Pan). Where's the best place to get get possibly a lower set? I've found a few good gasket locations, but I'm having trouble getting part#'s or listings for the ones I need.
mitsu does not use gaskets for the oil pan, and 3 out of 4 times i have tried it, they have leaked... just use Permatex Ultra Gray silicon... autozone carries it... same shtuff the dealer uses.
The 3 oil pump gaskets are about $15.. you'll just need oil return tube gaskets also, and you should replace your front crank seal while you're in there.
Should all run you about 25$ or so. (retail pricing, of course)
i bought the oil pan gasket and then added some rtv silicone and it worked great.
Originally posted by DSMRevolution
If you want, PM me with your VIN and all the parts you need. I will get you part numbers and Concelli's phone #. Let me know!
I deffinitely appreciate the help, but I went ahead and got a complete Fel-pro lower set ordered. I got the car torn down last night so I wanted to get the gaskets on thier way for reassembly. BTW, balance shafts are kind of a bi***!! Thanks for the responses!!
I deffinitely appreciate the help, but I went ahead and got a complete Fel-pro lower set gasket ordered. I got the car torn down last night so I wanted to get the gaskets on thier way for reassembly. BTW, balance shafts are kind of a bi***!! Thanks for the responses!!
Felpro is a good choice. My brother is using that for his lower set. Sorry for bumping into this old thread. Just wanted to share.
