Benji
- 117
- Mar 14, 2003
Since I've been logging my fuel trims I noticed that they would always start at 100% after shuttnig the engine off. This lets me to believe that the ECU is not keeping memory, therefor not getting a constant positive 10-12 volts.
I know that a fuse (very bottom right hand corner of passenger compartment fuse box) is responsible for the ECU backup, the footlights (when you open your car door) and your stereo settings. Since my footlights work and my stereo never looses its settings I figured the fuse must be good, but I checked to be sure and it is good. While I was looking at the fuse box I checked all fuses which all checked out fine!
Now, how can I find out whether or not infact the ecu is not getting a constant 12V? Anyone know the pin number? What if the pin on the harness side checks out fine?
Thanks for the help!
