Cirus_93TSI
- 658
- Jun 30, 2003
Glen Burnie,
Maryland
ok, so my car failed maryland emmisions for the exhaust, first they did a tailpipe test, and it failed because the hydrocarbon level was above the state limits
the guy that did the emmisions test had no idea what he was doing,m and he was fronting like he could drive a 5 speed, with my act 2600 he couldnt even get it into gear without grinding the hell out of the gears, and couldnt move it without stalling
so i made him get out of my car, get his supervisior, they i made the supervisor put it on the treadmill to test it again that way instead of another tailpipe test i neutral, the exhaust failed again, this time in every catagory instead of just hydrocarbons
so what i want to know is whats the easiest and cheapest way to make my car pass emmisions, if i boght a stock exhaust from a junkyard do you think that would make it pass? or could an old high flowcat that could be worn out and bad be the problem? it might mot be catching the bad things out of my exhaust like iut should
or is there some problem with how my car is running that changing the exhaust wolnt fix?
any help is appriciated, thanks
