Kicka$$93laser
- Jan 3, 2003
Pennsylvania
Alright, I have a 1993 Plymouth Laser 1.8 liter model with the manual trans. Maybe this has happened to someone before on here and they can help me. I was on my way home from work today when all of a sudden my car shut off. I had just put it in 5th gear and it just shut off. I finished pulling over to the side of the road with the rest of the momentum i had left. I went to start it up again, and it barely turned over. So I looked under the hood and saw that all belts were still on. I thought maybe it was my fuel pressure, so i checked that, sure enough, it wasnt the problem, so i checked my spark plugs, and i have no spark, i checked all my fuses, none were blown. So i tried to start it up once more and tried to see if i got any movement in the crankshaft, and no, there wasnt any, so then i realized maybe its the timing belt??? I dont know. But im desperate and Broke. It has 100k on itt, gas tank is full, oil is only bout a quart low so thats not the problem. Please any help is Appreciated, id be grateful.
