1g motor swap in to 2gHELP!!
japex84
Jan 9, 2003
hey my mechanic says that i need to change out my flywheel and clutch on my 2g tranny to make it fit the 1G motor is that true?
hey man yes you do have to change the flywheel
cause im assuming hes using a 6bolt engine...hint the name 6 bolt, which refers to the number of bolts that hold the flywheel..the engine on your old motor was a six bolt..
hey by the way can you take some pics of your ignition once the car is in the engine...pplease
im doing the swap my self
http://www.cardomain.com/member_pages/view_page.pl?page_id=410642
i got the ACT flywheel..
