PushinPsi
- 35
- Apr 1, 2003
OK i found my problem car was only running on 2 cyl. no spark so i gat a new innition ciol and it seemed to fix the problem i was running on all 4 again. the car remained parked. today i was and replaced my caps on the ecu put it all back and fired it up. running pretty good. and on all 4 again,
now i pulled it out of my garage about 100ft out my garage my car starts acting up again. i pull the plug and again running on 2 cyl the same 2 as before.
now this is my question
when i put my foot on the brake at idle the car will fire up all 4 as if nothing is wrong. or if its running i can push the brake and look 4cly and take my foot off and bam back to 2 cyl?????????wtf
i do have a rpm wire tapped on my cas, and all the wires on the cas and worn bad. but im guessing that the problem has soming to do with the brake system or maybe a vaccum line.
im stummped so any ideas wiil help thanks tyler
laugh. I've had a rough day:laugh: !!
