replaced power transistor, still won't start
91n/aeclipse
Dec 10, 2002
ok, here's the deal. I recently picked up a 91 Eclipse Gs with the 4g63 non-turbo and a 5-speed. It's been sitting for a while and needed some work to get it running. A preliminary check showed that all the parts are there, none of the wiring has been cut into and overall , everything looked to be in good shape. When attempting to start, the engine will rotate but not fire over. I've checked and made sure that it's getting fuel, the timing belt looks good and all electrical connections are together. I put it on a scanner and got an error code that indicated a bad power transistor, so I replaced it with a brand new one. Still no fire. Any suggestions? Thanks in advance.
