Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum > Problem Diagnosis
Problem Diagnosis Can't figure out the problem? Does the question not fit in one of the other tech forums? New Members can post here.
Reply
LinkBack Thread Tools
Old 10-11-2008, 12:24 AM   #1 (permalink)
New Member/Lurker
Region: Midwest
Classifieds Rating: (0)
Reputation: RickIntihar is an unknown
90 1G Auto Seat Belt Glitch
I just got a set of auto belts out of a junk yard car.
The drivers side works great, trouble free.
The passenger side however does not work at all. I do not hear the relay clicking at all. Not even any motor movement, like you would get if it was burnt up. I can move the track with an allen key on the gearbox.
I did the pin out tests listed here: http://img234.echo.cx/img234/8496/page27ls.jpg
I don't understand how you are supposed to get battery voltage at the terminals listed, it goes into no detail. I have continuity at all the correct terminals.
I pulled the relay off the passenger side and put it on the drivers side and it works properly, so I can eliminate that.
I'm thinking its the brain box, but its seems odd that one side would work perfect and the other would be dead.
What is used to switch the belts? Is there a trigger in the latch mechanism itself?
Has anyone else seen just one side go dead? I'm going to try and put battery voltage directly to the motor tomorrow to see if I can eliminate that as a problem.
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 10-11-2008, 10:20 AM   #2 (permalink)
New Member/Lurker
Region: Midwest
Tested the motor, works perfectly.
I still cant figure out how the door triggers the belts. I can see switch of sorts in the latch mechanism, but I can get it to trigger on the drivers door, making me think it may ground out on the striker when closed.
If I could figure out how to trigger the belts using whatever switches it normally uses, I can eliminate wiring and the brain box, which I would like to do.
Offline
Old 10-11-2008, 11:26 AM   #3 (permalink)
New Member/Lurker
Region: Midwest
Fixed.
Again, the dumbass that owned the car before me (or more than likely the ricer that owned it before him) went touching shit.
I pulled the door card off and the switch in the latch mechanism was just disconnected and dangling there.
Some people...
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Auto Seat Belt Issue Turblown Problem Diagnosis 7 04-22-2008 03:54 PM
90 Eclipse Talon GST GSX TSI 1G DSM Lower Rear Seat - DSM eBay Auction Admin eBay Auction Links 0 02-29-2008 09:10 PM
Metal box on driver side behind auto seat belt motor, what is it??? MG200 Newbie Forum 2 05-24-2005 07:32 PM
1G Seat Belt Retractor - EVERYONE WITH A 1G PLEASE POST!! EHeye Newbie Forum 23 09-20-2003 06:20 PM
SEAT BELT HARNESS / Belt BAR geekyguru Appearance/Interior/Exterior 1 08-14-2003 01:52 PM
Page generated in 0.11122489 seconds (70.27% PHP - 29.73% MySQL) with 10 queries
