Does anyone have a Cruise Control Assembly Diagram
95CarbonEclipse
1,279
5
Sep 16, 2005
Yakima, Washington
I recently removed the black Cruise Control box on my 2g (the thing with all the pulley's inside of it) when doing an intake manifold install and am now trying to put it all back together. Does anyone have a diagram of how the cables are attached inside this black box? There's 3 pulley's, with each pulley having a spot to mount the cable on both sides of the pulley. I thought I had it correct but when I finally mounted the cable directly to the TB, it was not taunt. I know which cable is supposed to be attached to which pulley, I'm just not sure which, of the 2 ends, each cable mounts to.
Thanks.
Thanks Snowborder. I think I may have gotten it. The pedal just feels different when I press it down now. I'm assuming this is due to the new EVO 3 TB that I installed during the intake mani swap (the springs on the throttle plate aren't as firm as my old ones, I think). I'm going to see if my buddy will let me pull the cover off of his CC box just to double check that I have everything properly put together.
