gofer
Moderator
- 8,164
- 1,549
- Feb 18, 2006
South Gilbert,
Arizona
just recently did a evo 3 16g turbo install with a evo 3 manifold running a 46mm external wastegate. the guy i bought the turbo from said it held 16psi strong before he took it off his car and now i can't get it to build boost. my vacuum at idle is 20 but half throttle/WOT my car just makes a lot of noise and the boost gauge sits at 0. when i give it gas it sounds like a super charger whining but im going no where... can my turbo be leaking somehow? we did a boost leak test and it sounds like there's air escaping around the turbo somehow... anything will help at this point. i guess im not sure if i hooked the WG up correctly either, blocked off the top port on it and ran a vacuum line to the LICP and left my MBC disconnected altogether...thanks for the help guys. (picture is of the car after the install)
next time i guess
