Running fine, then clicking and dieing, then dead. No start batts dead. HELP ASAP!!!!
1gcrazy
1,552
9
Apr 6, 2005
Fountain, Colorado
It was running fine, was driving then intermittently it would run fine then die and kept doing it very quickly. At the same time a clicking near the ecu was following the rythym.
Then after it dies I can jump start it, it runs great for a few moments then does the same thing and dies. It wont start back up under its own power.
I need this fixed SOON!!
I have a feeling its the ECU or a bad alternator.... IF its both, I have both spare parts. HELP!
I would start with check for a dead battery and the alternator not charging. That could be due to a bad alternator or a blown fuse.
I've posted several times what you should be watching for to tell id the ECU is resetting or not powering up. It's pretty simple, if the CEL doesn't turn of for five seconds when you first turn the ignition on and then go off your not going anywhere. On turbo cars the boost gauge will go to 0 and start there until you start cranking.
Get a voltmeter and measure the battery voltage at rest, with the ignition on, and while cranking.
  • For sale 4G63 Pair of fog lights
    Pair of Fiat 500 fogs. Complete with mounting brackets and hardware. Both lens are in really...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
