2soon2
- 39
- Jul 11, 2006
Moncks Corner,
South Carolina
Ok I had a 91 oil filter housing and oil pressure was fine on aftermarket gauge. It started leaking so swapped to a 90 style. Oil pressure is was high idle is 20psi and 3000rpm its 100psi. So I took it off cleaned it out real good, checked relief spring and piston looked kind of burnt so I bought new ones ported relief hole (since I was in there) to nice big egg shape. Cleaned it up once more and made sure piston moves freely. Put it all back together. Still high pressure same readings. Read that if balance shaft belts is broken it might cause high pressure. Belt is ok. Swapped sending units and gauges and it still reads the same. After a while of pressure like that oil filter starts leaking. Cleaned cooler out (still same pressure) then I by-passed the cooler just incase it wasn't fully clean (still same pressure). Last ditch effort was to port the hole that is on top of the piston and wouldn't you know i still have the same oil pressure. Is there anything else that I can do/check? Need help big time! Whats the difference between the 90 housing and the 91 housing other than the way it cools. Is any of the passages larger or something? Thanks
Well I opened it up and saw the guy before me removed the b/s. I have seen all the pictures and ported my relief hole like it. I have tried different gauges. I have bought new oil bypass piston and spring. Still I havent had the slighest luck of dropping my oil pressure. Can anyone please help?
