cavillac
- 117
- Sep 30, 2007
Omaha,
Nebraska
Hello DSM tuners, I recently bought a 2g talon and it didnt have no heat, at the time I figured it was just because it was low on coolant due to the leaking radiator end tank, the previous owner decided to put some stop leak in it
Anyway, I replaced the radiator, put a hose through the heater core for about 30 minutes and that didnt help, the thermostat didnt need to be replaced but I figured I might as well since I already had it out, of course that didnt help. So I used an infared thermometer and at the end of the heater hoses attaching to the Tstat housing I am getting 175 degree coolant, then toward the heater core I am getting 114 in and 71 degree temperatures out the other side.. the car warms up fine and doesnt overheat it just seems there is either a block in the lines or there isnt enough flow in the cooling system for the coolant to make it into the heater core.
Anyone ever seen anything like this before?
