csto
- Nov 9, 2007
Hamilton,
Montana
While cruising normal, my car all of a sudden lost fuel. No matter what I do with the gas petal, it just keeps decelerating and when I put it in neutral it stalls. Now it is stuck and when I start it, it starts for about 3 seconds, it holds idle, I can rev it if I want with no problems at any rpm, then it'll just cut fuel again and die. Could this be an ecu problem, injector problem or fuel pump cutting out? The electrical system seems fine otherwise. The past week or so under no acceleration (the car is fine under hard acceleration) it feels like I hit the fuel cut off every once in a while but comes right back on, just a real quick jerky feeling coming from the engine. Any help would be greatly appreciated. Also when starting it over and over, it doesn't seem to get flooded so I think its a fuel issue and not a spark issue.
