Raptoreborn
- 82
- Mar 6, 2007
Thornton,
Colorado
Hello Dsmr's
I was in the process of my winter bolt-on build up on my 2g. When I noticed the water temp sensor wire connector not fully on. It was very noticeable the water temp sensor had two prongs. Okay,so I hit up the closes mitsu parts dealer for the correct 3 prong temp sensor. Whats funny is I did a motor swap about a year ago but never noticed this stupid mistake
. Also the reason for the upgrades are the whole stuttering BS. still a issue!
My plans are to beef up the fuel system, injectors, fuel pump, fpr, and for good measure a fmic.
I guess my questions are:
1. Would this cause the radi fans not to kick on? Thank god for a/c button!
2. " "for fuel starvation at high rpms (3500 & up)?
3. " "to over heat?
. Also the reason for the upgrades are the whole stuttering BS. still a issue!My plans are to beef up the fuel system, injectors, fuel pump, fpr, and for good measure a fmic.
3. " "to over heat?
