1990 ecu in a 92
Duke901
111
Nov 29, 2005
Sylvania, Ohio
i just bought a MD128625 ecu it says highline on vfaq, is this a 1990 ecu. Why i ask is because i put it in my car and it runs really rough. if i hold the throttle open at any rpm it misses like crazy it seems to idle surge, and it dont want to hold its idle when i let off the gas. so is it a 90 and If it is i just have to switch pin 6 and 14 and it should be ok.
thank you
thank you
youll need the transistor pack, coil pack and dash tach from a 90 as well. The 90 ecu is a bit inferior to a 91-94 though, i would try to sell it and pick up a 91-94 instead.
Joe
or you can just swap #'s 6 and 14 with each other and it should work ok for you. It does with a 90 ecu in my 91 tsi anyway...
thats what i was thinking, i think if you have a 1990 car you have to change more things then just the 6 and 14 pin. but when you have a 91 to 94 car and want to use the 90 ecu you just have to change the pins around and it should work fine.
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
