JFZERO ECLIPSE
- 749
- 11
- Jul 20, 2004
Altoona,
Pennsylvania
After searching I cant seem to find an answer to my problem....
On my newly aquired 99 GSX the previous owner decided to cut the sockets for all the bulbs to the taillights out....
Well getting a new line from the little white plug on both sides where the wires go to the taillights is not a problem.....
There seems to be on my car 2 wires that start out right before the plug starts...
1 wire is black (not sure if any markings...) and
1 wire is green with a white stripe.....
I cannot figure out what these go to???? Or if I got a plug what they go to....
Also when I went to the local junk yard I found a 95-96ish model eclipse and cut some plugs out of it
The plug I cut was in the same area where the above listed wires are so I assumed they were the same, here I got 2 plugs both black but with 3 wires coming out of each.
1 black (not sure on markings)
1 green with a white stripe and
1 more green but with 2 dots close together every 3-4 inches....
Anyone who has their car gutted or stripped so they can easily see or anyone familiar with this plese help....maybe you could help me out wiseman steve since you know your electronics very very well...
Pic #3 looks like the speaker wires. Oh u say it is not. Well then it looks like a wire to some power door locks. Have you followed the wire to see where it runs to?
